hah, never. my built engine has some bad bearings. got a new crank for it.eh? wrote:Did you figure out your oil pressure problem?
Are you monitoring your oil temps? I wouldn't be surprised if you're slowly frying your bearings... Anything over 110 degrees C is bad.krayton wrote:so, while im waiting, got a brand new used block. comps test great, but after my 1st track event, my oil was bouncing near 12-16psi. of course this is in 100degree az heat and no oil cooler. also running 0w-20 royal purple.
This is like the minimum rule of thumb for track use. I wouldn't be happy with only 60 psi of pressure...krayton wrote:edit: i do find most people saying add 10 psi for every 1000rpm on top of your idle psi
You gotta remember pressure is the resistance to flow. Higher pressure isn't always better and is why I'm not very concerned.mattblancarte wrote:
Higher pressure may not always be better, but it means that you're pushing more oil through to create that resistance.eh? wrote:
OEM bnr34 rb26 pump.krayton wrote:matt what kind of pump do you have? i thought the relief valve was 80psi.
that is normal, given an oem pump, hot oil temps (probably 240F+ I'm guessing with just the factory oil to water cooler), and 0w-20. Not saying it's good for the motor, but that is expected given your conditions and oil weight.krayton wrote:comps test great, but after my 1st track event, my oil was bouncing near 12-16psi. of course this is in 100degree az heat and no oil cooler. also running 0w-20 royal purple.
