krayton »
https://forums.nicoclub.com/krayton-u8223.html
Tue Dec 09, 2008 5:52 am
Yeah i put together this engine. So talking to myself gets a little wierd.
My first build the builder put it together leaving no clearances on the main and trashing that engine.
As for clearances, all of them were within spec. the mains were a little loose, but all within the fsms spec.
rods were right on minus 2 of them. 1 was a little loose and one a little tight. But again, they were both within spec. The few that were slightly off, I used a micrometer and telescoping gauge to get it on the dot.
Again im not sure. Im looking at possibly the bolts on the oil pump backing out?
I installed a mech gauge and was reading 10psi when the oil warmed up. If it was a bit higher I might just try running it. Also the problem was that before the turbo blew, I was running 1 bar at idle. All these things just happened at the same time. Blown turbo, low oil pressure.
But other then the low oil pressure, the car sounds perfect. No odd noises at all.
