FSM here incomplete
lschwarcz
Car: 2007 G35 Sedan (V36)
Hi everyone,
My first post here and sorry if this has been covered already. I did search around but have not found an answer.
The FSM here for 2007 G35 (Coupe & Sedan) are both missing at least one section. There should be two sections on air bags:
  • SRS AIRBAG (filename: sr.pdf)
  • SRS AIRBAG CONTROL SYSTEM (filename: src.pdf)
The first one, "sr.pdf," is missing from this site. I tried a Google search and couldn't find this file on other sites with manuals. I did find it for the 2008 G35 Coupe. It'll likely be nearly (if not exactly) the same but it would be nice to have the right one for my car.
Does anyone have the sr.pdf file for the 2007 G35 Sedan (or even the Coupe)? If so, maybe it could be posted in the FSM section or maybe you could e-mail it to me?
Thanks in advance!
Larry.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO!
After taking a quick look, I can see why you might think those files are missing.
From 2003 to 2007 Infiniti listed all of the airbag details under one heading named Supplemental Restraint System (SRS). From 2008 onward they broke it into the two separate groups SRS Airbag and SRS Airbag Control System. So the info you need is in fact there.
Hope this helps!
audtatious
If you are using the fwd.pdf for some reason none of the links work from it. src.pdf does exist and works if you click on the link. sr.pdf is missing and I don't have a local copy of it either so it must have been missed as a download. I'll see if I can find a version for upload.
