FSM for 88 b12 or help troubleshooting tbi issue
mys13240
Car: 1990 240sx hatchback(for sale) 1989 240sx hatchback (KAT PRoject)
I'm looking for a Factory Service Manual for an '88 sentra. I'm thrying to troubleshoot my problem. I don't want to throw parts at it. It will idle but won't rev past about 2500 rpm's and is basically not getting fuel and you have to keep giving it just a little throttle or it will choke out and die. it's not missing though. I don't know anything about this stupid TBI s***. Its getting good pressure into the throttle body and the filter is new and so is the pump(fix one thing and something else brakes). I thought it was an ignition issue at first because the contacts on the inside of the cap and on the rotor were corroded. I filed them clean and it ran fine when i pull it back together. I then did a complete tune up the next day. Cap, rotor, wires, plugs, air filter, fuel filter. Now it's running the same. I thought that maybe the new stuff was bad so I swappeed it back to the old parts but to no good. I put the new stuff back on. If you have a FSM for this or know about these tbi ga16e setups and can help I do appreciate it. I'm thinking it's the injector, but want to be 100% before I take it apart and buy a new injector. I was gonna try and sell the car but it started acting out. Its worth more running, but i don't want to put too much more in it.
jonusb2
Attitudes towards new york asian escorts criticism differ from person to person. Some people will become annoyed if they are criticised and new york escort they will try to excuse themselves by all means. Some new york asian escort people tend to be indifferent criticism. They just regard criticism as nonsenses. But still some people new york escorts accept criticism modestly and try to find their
mys13240
jonusb2 WTF is that about?
Well I replaced the injector. It still wouldn't idle or rev past 2500rpm. I thought it might be the tps. I unplugged the tps and it idled smooth but wouldn't rev past 2500rpm still. I replaced tps and and now it will idle but still won't rev past 2500rpm. I then checked the troble codes on the ecm. It is throwing a code 12 which is air flow meter. I pulled it out and have called every place I know off trying to find one but have had no luck. Anybody have one or know where I can get one? Found one on ebay but the connector only has 5 pins where mine has 6 pins.
This is one on ebay
This is what mine looks like
