FS: WIDE Custom 19" BBS LM 3-piece
Lugs, studs, pressure sensors, hubcaps, spacers, wheel accessories, etc.
Chris_tA_4
Car: Bagged B6 A4
Selling my custom built 3 piece 19" BBS LM wheels. Yes, that is correct, these are 3 piece. For those not familiar BBS LM's are 2 piece from factory. The work/conversion was performed by Paul Ehrlich @ ewheelworks. All four wheels started out as original LM 154.
These were mounted on my Mercedes W212 for a brief period. Tires have a lot of life left, they are practically new. The wheels were recently polished and vigorously cleaned and haven't been driven on since.
PRICE:
$6,000
No trades
Willing to ship at buyers expense
*REDACTED* call/text for fastest response
Chris
SPECS:
19x10 +32 w/ 2.5" lips Nitto 555 235/35/19
19x12 +25 w/ 4" lips Nitto 555 275/30/19
5x112 (can use wobble bolts to fit 5x114 hubs)
66.6 mm centerbore
Black chrome plated faces (polished)
Polished lips
Gold plated bolts
Red/Gold BBS center caps
Black powder coated barrels
Reverse mounted
No cracks, bends or curb rash
No TPMS
Missing one BBS valve stem cap
ALSO INCLUDED IN THE SALE:
(2) 2" lips
(2) 8" barrels
Reason: CLOSED
Chris_tA_4
Car: Bagged B6 A4
There are different wheel specs available other than of what they are currently constructed as. See "alternate specs" section for alternate wheel width and offset options.
PRICE:
$6,000
No trades
Chris
SPECS: (as currently constructed)
19x10 +16 w/ 7.5" barrels & 2.5" lips on Nitto 555 235/35/19
Offset Calculation --> 6.25" backspace, 11.25" overall width / 2 = 5.625" - 6.25" = .625" x 25.4mm = 15.875mm ~ 16mm
19x12 +22 w/ 8" barrels & 4" lips on Nitto 555 275/30/19
Offset Calculation --> 7.5" backspace, 13.25" overall width / 2 = 6.625" - 7.5" = .875" x 25.4mm = 22.225mm ~ 22mm
66.6 mm centerbore
Polished lips
Gold plated bolts
Reverse mounted
No TPMS
ALTERNATE SPECS: (if the wheels are disassembled and reconstructed by mixing and matching the different barrels and lips)
There are (4) 8" barrels, (2) 7.5" barrels, (2) 4" lips, (2) 2.5" lips and (2) 2" lips.
Options 1-5 below apply to reconstructing the 19x10 wheels (currently 7.5" barrels & 2.5" lips):
1. 19x9.5 +22 w/ 7.5" barrels & 2" lips
Offset Calculation --> 6.25" backspace, 10.75" overall width / 2 = 5.375" - 6.25" = .875" x 25.4mm = 22.225mm ~ 22mm
2. 19x11.5 +3 w/ 7.5" barrels & 4" lips
Offset Calculation --> 6.25" backspace, 12.75" overall width / 2 = 6.375" - 6.25" = .125" x 25.4mm = 3.175mm ~ 3mm
3. 19x10.5 +22 w/ 8" barrels & 2.5" lips
Offset Calculation --> 6.75" backspace, 11.75" overall width / 2 = 5.875" - 6.75" = .875" x 25.4mm = 22.225mm ~ 22mm
4. 19x10 +29 w/ 8" barrels & 2" lips
Offset Calculation --> 6.75" backspace, 11.25" overall width / 2 = 5.625" - 6.75" = 1.125" x 25.4mm = 28.575mm ~ 29mm
5. 19x12 +3 w/ 8"barrels & 4" lips
Offset Calculation --> 6.75" backspace, 13.25" overall width / 2 = 6.625" - 6.75" = .125" x 25.4mm = 3.175mm ~ 3mm
Options 6-10 below apply to reconstructing the 19x12 wheels (currently 8" barrels & 4" lips):
6. 19x10.5 +41 w/ 8" barrels & 2.5" lips
Offset Calculation --> 7.5" backspace, 11.75" overall width / 2 = 5.875" - 7.5" = 1.625" x 25.4mm = 41.275mm ~ 41mm
7. 19x10 +48 w/ 8" barrels & 2" lips
Offset Calculation --> 7.5" backspace, 11.25" overall width / 2 = 5.625" - 7.5" = 1.875" x 25.4mm = 47.625mm ~ 48mm
8. 19x11.5 +16 w/ 7.5" barrels & 4" lips
Offset Calculation --> 7" backspace, 12.75" overall width / 2 = 6.375" - 7" = .625" x 25.4mm = 15.875mm ~ 16m
9. 19x10 +35 w/ 7.5" barrels & 2.5" lips
Offset Calculation --> 7" backspace, 11.25" overall width / 2 = 5.625" - 7" = 1.375" x 25.4mm = 34.925mm ~ 35mm
10. 19x9.5 +41 w/ 7.5" barrels & 2" lips
Offset Calculation --> 7" backspace, 10.75" overall width / 2 = 5.375" - 7" = 1.625" x 25.4mm = 41.275mm ~ 41mm
(2) 2" lips
(2) 8" barrels
No need to repost. FWIW, 5x112 is probably better suited to a Euro car board.
No one buying that level of wheels (and they're amazing) is going to risk janky fitment solutions on a 5x14.3 pattern.
Return to “Wheels / Tires (for sale)”
