FS: T3 Topmount manifold.
teddy
Car: Saab Turbo and MR2
I'm selling my t3 top mount manifold. This particular manifold is 304 low carbon stainless steel, 1.5" diameter piping. All flanges are mild steel. The manifold was tig welded by my cousin, who is a general manager of a large welding shop in Illinois. The welds are extremely nice and clean, and this manifold is sturdy. Turbo flange is a t3. I was running a garrett t3/t04e with no clearance problems. I can't guarantee what other t3's will fit. 38mm wastegate flange on the bottom. I was using a Tial. Fit fine. I also coated the manifold with some VHT Flameproof and sent it through some heat cycles and it seems to hold up. Manifold has literally 3 miles on it. The inside has a little bit of splatter from where I plasma cut it, but it's nothing to worry about. Asking around $200. Hardware you see pictured is included. [IMG]
Ca_laurier
willing to ship to canada??
also i don't have paypal so it will be a money order be fine???
email me at [email protected]
iliketocrash
if he doesn't buy then let me know and i'm paypal [email protected]
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
manifold looks good! ive been wondering how that VHT flame proof paint would hold up, most high temp paints burn off at startup.
did you buy a tapped t3 flange? i almost like that mounting of the flange better then using the radius plate like we normally do.
jon
teddy
Not_a_sr wrote:manifold looks good! ive been wondering how that VHT flame proof paint would hold up, most high temp paints burn off at startup.
jon
Thanks. The flameproof actually works quite well. I didn't want to spend money to get it jet hot coated, so I tried this stuff out. It was worth 7 bucks. Needless to say, VHT seems to be much better than other sprays I've used.
I did use a tapped flange that was already rounded out on the bottom to fit the 1.5" piping. I bought it from BMC Race.
float_6969
Bump for a good looking mani!
Ca_laurier
never recieved an email...
teddy
Ca_laurier wrote:never recieved an email...
I sent you an email a few days ago. It said it went through fine. It didn't get put into your junk mail did it?
Ca_laurier
ya didn't recieve it.
well sell it to iliketocrash
i should be spending my money ong my work xt7's anyways
iliketocrash
YAY!
teddy
iliketocrash wrote:YAY!
Sent you an email earlier. Unless my email is acting up again, this one should have gone through.
iliketocrash
mail sent. btw, i only received one e-mail from you. :-)
