FS: SR20DET Turn key swap.
Intake, exhaust, fuel injection, sensors, driveshaft, transmission, clutches, flywheels, manual swap components, differential, axles, cooling system, ECU, forced induction parts, catch cans, complete motorsets.
deemoetee
Car: 300zx
Hello, Selling a fully built SR20DET turn key swap. Will include everything needed to swap into an S13 240SX the parts lists are as follows
* ACL Main & Rod Bearings
* ARP Main & Head studs
* Manley Rods & Pistons
* Balanced Crank
* APEXi Head Gasket
* Brian Crower 264 cams
* New OEM Springs, Retainers & Lifters
* New OEM Timing Chain Kit, Cam Gears, & Oil Pump
* ISR V2 Exhaust Manifold
* New Garrett T28 S15 Turbo
* Braided Turbo Oil & Coolant Lines
* ARC Oil Pan
* Koyo Radiator
* Raidum Fuel Rail
* Injector Dynamic 1050cc Injectors
* P2M Coil Packs
* AEM CAS Trigger Wheel.
* Wiring Specialties Pro Series Engine Wiring Harness
* S15 Link-NS15X Link ECU
* Action Clutch Stage 3 Clutch
* SR20 Transmission < ~1500 miles
* ISR Short Shifter
Engine has been tuned and you can come and see it running and driving before you buy it. It will be pulled for you as well. Reason for selling is the car is getting a new set up.
Asking $11k for the full swap, it can be installed for $13k.
If you're interested, please contact any of the following: *REDACTED*.
Thank you!
Reason: CLOSED
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
:poke: What's the status on this? Should the thread be closed? :gotme
Return to “Engine / Drivetrain (for sale)”
