FS: Redtop T25,intake elbow, intake, dump pipe
Banisher
I have a Redtop T25 for sale. Used on my car for about 2 months before I swapped it out for a T28. Used on stock boost, no smoking, minimal shaft play. Already clocked so just plug it up and go. $170 + ship
originalsin
how much minimal shaft play??? shaft play that going to really hurt the turbo? like will it need a rebuild?
Banisher
There is shaft play from side to side but it barely moves maybe a mm. There is no in and out play. Does not smoke or spew any oil so the seals are still good.
originalsin
does the wheel contact the housing?
Banisher
Does not come in contact with the housing, wheel spins freely
float_6969
Guys, lateral shaft play on a non-ball bearing turbo is normal. As long as it doesn't have any axial (in and out) play, it's fine.
I haven't had it in hand, but if it's as he's describing, it's got my approval...
originalsin
ok i will like def take this, ima sending u an email
