These items are immediately available (OEM unless noted otherwise):
1. New-style injector conversion kit for ’90-’94 TTs - $500 shipped.
2. Zshack socketed ECU and tune - $600 shipped.
3. Bose radio - $250 shipped.
4. Hood insulation - $200 (local pickup only).
5. v2 PTU and sub-harness - $65 shipped.
6. Mid-pipes with catalytic converters - $200 plus shipping.
7. Cargo cover - $200 plus shipping.
8. Airbox and tubes - $150 plus shipping.
9. AIVs - $60 plus shipping.
10. Boost solenoids - $55 shipped.
11. PRVR, AIV, EGR solenoids - $35 shipped, each.
12. EGR valve & tubes - $75 plus shipping.
13. PRVR canister - $30 plus shipping.
14. Boost hoses (2 good, 2 not-so-good) - $40 plus shipping.
15. Assorted under-hood hard lines - $20 each, plus shipping.
16. Carbon canister - $75 shipped.
17. Hatch counterweight - $25 shipped.
18. Front license plate bracket - $85 shipped.
19. Nose panel bracket - $40 shipped.
20. Unorthodox Racing alternator pulley - $40 shipped.
These items will be available once work begins:
21. MAF sensor - $150 shipped.
22. Hallman Pro RX boost controller - $80 shipped.
Detailed listing with photos:
1. New-style 370cc injector kit. I installed this early-to-new style conversion setup from Bernie in December 2019 (new-style injectors fitted in early-style rails for ’90-’94 TT engines) and it continues to perform flawlessly. I’ve put about 7k miles on the car since then. Also included will be a new plenum gasket, 6 new injector adapter harnesses and the newer (but used) short section of fuel hose that connects the rails. These are still in the car, but I’m at a point where I will pull them off if someone is ready to buy. I can also include fuel hose clamps if desired - $500 shipped.
2. Socketed ECU w/ Zshack tune for 93 octane, single intake, manual transmission, federal emissions, speed limiter removed, EGR functions disabled. This is still in the car, but I’m at a point where I will pull it if someone is ready to buy. - $600 shipped.
4. Hood insulation with all 19 clips (local only) - $200.
5. v2 PTU and sub-harness - $65 shipped (PTU - $50, harness - $20 if separate).
8. Airbox w/ upstream inlet tubes - $150 plus shipping. One of the threaded inserts used to close the air box is missing.
9. Air induction valves - $60 for the pair, plus shipping.
I'll include everything shown so you have the fittings, but use the original hose at your discretion.
11. PRVR, AIV, EGR vacuum solenoids (bracket(s) included as requested) - $35 each, shipped.
12. EGR valve (with bolts) and plenum tubes - $75 for all, plus shipping.
I'll continue to try and remove the leftover manifold tube and fitting, but I don't have a vise on my bench.
14. Boost hoses (two have torn/deteriorated openings) - $40 plus shipping for the two good ones.
I can include the damaged hoses if you like for no additional charge - just let me know.
15. Coolant/vacuum hard lines - $20 each or $90 for all of them, plus shipping.
Crazy to think someone would want to un-delete these, but if someone is doing a BaT prep restoration or the like, I have them.
16. Carbon canister with bracket - $75 plus shipping.
17. Rear hatch counterweight - $25 shipped.
Here are items that will be available once I get into the work:
22. Hallman Pro RX manual boost controller - $80 shipped.
I'll reply to this post with any updates/additions. Everything worked as it should when it was on the car, but I cannot make any guarantees. Shipping is assumed to be to the continental US, international or otherwise will be additional. Thanks!
