Chris859 »
https://forums.nicoclub.com/chris859-u44940.html
Tue Oct 30, 2007 6:10 pm
I have the manifold to turbo gasket(turbine inlet), the 5 bolt turbo outlet gasket(dump pipe), the 3 bolt compressor outlet gasket, and the 6 copper washers for the banjo fittings on the coolant lines.
On an after thought, I also have a second gasket for the turbo to manifold connection - I found one of the stamped stainless gaskets also brand new that I had laying around. So ill throw that one in for free to go with the others
Modified by Chris859 at 9:26 PM 10/30/2007
