FS NY: M35 18" Rims + TPMS
Ilya
Finally got time to get the tires taken off these wheels and the TPMS separated from them.
Wheels:
Model: OEM Non-Sport
Offset: +47
Weight: 25lbs
These go for about $250/rim in lightly used/refurbished condition...so I'm going to start at $550 shipped for the set, negotiable.
Supposedly, Sears thought one or two may be *slightly* (emphasis on slightly) bent...but I can't tell which ones and they didn't ride bad at all so I'm not even sure if Sears was accurate.
They will definitely need to be refinished, unless you plan to use them in the winter.
Pics:
TPMS: - SOLD
Infiniti OEM TPMS. Part number is 40700-CD001. Used, but when I change wheels/tires to another complete set (with new TPMS), these were 100% functioning. As they were taken off without breaking, you shouldn't need a TPMS rebuild kit to install them (you may want to double check just in case though).
Price: $85 for the set. A buyer on here has dibs right now, but I'm posting this here in case he falls through.
Pics:
Ilya
TPMS sold.
Ilya
Bump.
