FS - NEW Techna-Fit Stainless Steel Brake Lines (and Clutch Lines) for Nissans
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
BrianV
Car: 07 G35S 6MT, 02 MDX-T AWD
These are brand new, DOT certified, Technafit lines. The prices below are for SINGLE orders. This is NOT a group buy, and has been OK'ed by AZhitman via Nismo_Freak..
NOTE: Texas residents pay 8.25% sales tax.
Why do you need stainless steel lines?Stainless Steel Brake Lines are an extremely cost-effective way of increasing your car's braking feel and performance. From the factory, a car's brake lines are made out of rubber. Over time these rubber brake lines wear down and become weak, possibly even broken. If a brake line breaks or leaks, brake fluid begins to leak out at a very fast pace. Brake systems use brake fluid and pressure to push calipers or drums together, effectively slowing down your wheels. If you run out of fluid due to a leak or break, you will lose all braking power and the ability to safely stop your vehicle. Stainless Steel Brake Lines use a stainless steel braided sleeve with high quality stainless steel connections. Stainless steel can handle the elements and constant use, providing you a more reliable and safer braking solution.
In addition to safety and longevity, Stainless Steel Brake Lines increase your braking performance and braking responsiveness. Factory rubber brake lines expand when brake fluid is moved through them, resulting in a mushy, soft brake pedal feeling. The expansion of the rubber lines during braking also reduces the braking power sent to the calipers or drums, reducing the effective power of the brakes. Stainless Steel Brake Lines are much stronger and do not expand, resulting in maximum braking power sent to the calipers or drums.
These Stainless Steel Brake Lines are D.O.T. (Dept. of Transportation) approved and made to MVSS-1006 specifications. Many aftermarket brake lines and stainless steel brake lines are not D.O.T. approved.
Stainless Steel Brake Lines are extremely affordable and are one of the best aftermarket values out there and cost much less than OEM rubber brake lines.Below are some pictures of some Maxima lines I have in my garage right now. You can see they're factory sealed and impressive quality. They also come with all the necessary hardware:
The paypal address is [email protected]. You can learn more about our company by visiting http://www.centexracing.com.
Prices are for the front and rear lines, shipping is free!
240SX (Banjo / IF) - $90 (Specify Z32 brake fitment if needed and S13 or S14)S12 - $90300ZX (Z32) - $90G35 / 350Z - $120B13 - $90 (Cars with Rear Disc Only)NX - $90 (Cars with Rear Disc Only)B14 - $90 (Please specify if you have rear drums or discs)B15 - $90 (Please specify if you have rear drums or discs)Maxima - $90 (Price for all Gen's - Specify Year and 3rd gen specify Rear Disc or Drum)
Remember: Texas residents pay an additional 8.25% sales tax.I also have 240SX clutch lines for sale at $20 each with the purchase of a brake line set.
If you don't see your application here, post a reply with your application and I will get you a price!
I'm a new sponsor to NICO, but I'm an active member under the same handle on maxima.org and g35driver.com. I've been working on automotive message boards since 1999 and have an established company, Centex Racing LLC. If you have any quesitons or concerns, please contact me via PM or email ([email protected]).
Reply to this thread if you have any questions.
Thanks,BrianV
slipnfall
Car: '06 D40
Just a quick question: in general will stainless lines put any more strain on a master cylinder or brake booster?
BrianV
Absolutely not. If anything it puts less stress on the master cylinder and booster. Rubber stretches and expands making the master cylinder work harder to deliver the same amount of fluid to the piston in the caliper.
The difference is negligible though, but to answer you question again, NO it absolutely doesn't have any negative effects on the rest of the braking components!!!
slipnfall
Car: '06 D40
Great, thanks for the reply! Too bad I can't get the ATE super blue fluid locally, or I'd be doing this sooner(just waiting on an excuse to order something else from a vendor who supplies it).
Are you capable of doing custom conversion lines BTW? ie for folks who have 240sx to 300zx caliper swaps.
Cheers,Jamie
BrianV
slipnfall wrote:Great, thanks for the reply! Too bad I can't get the ATE super blue fluid locally, or I'd be doing this sooner(just waiting on an excuse to order something else from a vendor who supplies it).
Cheers,Jamie
Yes, you can see above that we offer Z32 upgrade lines (it's in paranthesis before S13/S14). It's the same price.
Return to “Advertisers' Marketplace!”
