negative, its already been bought and paid foryourmomsrps13 wrote:still for sale?[email protected]
Oversteer's ecu was setup just to get his motor started and idling. At first the ecu was setup for stock motor but didn't realize oversteer had 450cc injectors.tyrannix wrote:was the engine it was set up for all stock? mods?
just so i know what the starting point is, i might not even use the powerFC now (just so i dont waste time tuning it when im going to switch later on MAP sensor + extra input/output controllers FTW)
CJ
Unless you plan to rev over 12,000 rpms I dont think you have to worry about FORD system keeping up, the creators already bench tested them to 17,000 rpms.tyrannix wrote:yeah, im going to use all the standard junk that he is sending me(btw, didnt get to send out the crank pulley today, it will go out tomorrow morning after i get off work)
after i get it running, and the engine broken in. then the megasquirt, injectors and FPR go on. if the ford unit cant keep up, then ill get a MSD box.
and when its time for teh AC to go in, then its time to switch to a hall sensor
looks like ill be selling the Z32 mafs and powerfc here shortly (after the megasquirt is up and running and everything i thought it would be)
send offers for my powerfc to tyrannix at gmail if you want to tho
CJ
how is it ghetto rigged? you said it was welded on the AC pulley.oversteer180 wrote:Im sending him out all my ford edis4 stuff, along with my 36-1 wheel ghetto mounted onto the crank pulley,vr bracket, and vr sensor. The stuff I made looks kinda goofy, but it worked to get it started and running. UMS_CA has pictures of the stuff I made somewhere.
so ill be able to use it as this one is a MS II, right?UMS_CA18DET wrote:GPIO is still beta testing meaning its out but only a select few people have prototypes and doing real world testing. Its only compatible with Megasquirt II. You can add up to 45 Input/Outputs as well as the 200 port settings.Should be another month or two.
thats cool, thanks, but im going to switch it to a hall effect setup, unless you can stick a trigger wheel on the back of the pulley, so all 3 (alt, AC, PS) are available.Not_a_sr wrote:if you want a pulley that will work with PS let me know, i can have then machined to work, i just need a 36-1 wheel and pulley.
also if you dont want to hassle with the ford EDIS coil pack and its funny plug wires you can use a dodge neon coil pack, or even two GM coil packs. or if you really want to experiment, you can probably wire up the CA18det coils to fire with the EDIS ign module. Im personally using the neon pack, im buying a MSD version for 75$ once the cars running.
Sure is because Nissan electronics are completly garbageyourmomsrps13 wrote:dont mean to thread jack but, i spoke to the megasquirt guys in person and they said i can run my OEM CAS (cam angle sensor) with their systems, is there a better reason why you guys arent?thanks
