FS: Ca18det Ignitor
Tweaktac
Hey everyone, I have a Ca18det Ignitor for sale...if you are interested please drop me an email at [email protected]thanx, TroyHere is a pic...
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
How much are you asking shipped to 23322 zip?
XtremeHKS
Do you have a drop resistor for sale?
Tweaktac
Hey there, Its on ebay and its up to like $45, you can either bid on it, which ends in like 6 hours, or you can contact me at [email protected] asap and I will close the auction early for $65 shipped.... so please let me know... thanx! BTW, no drop resistor, sorry
nab911
Car: 93 Nissan 240SX SE
Is the ka drop resistor the same as the ca caus if so i have one for you xtremeHKS
biosehnsucht
Whoa, I never knew KA's had a dropping resistor, but looking at the FSM it's the same R-value if not same physical connection.. pinouts the same too.
NOTE: Only the SOHC KA appears to have one that would work, the DOHC doesn't.
Oops, I'm wrong. I was looking in the PDF FSM I have not my real FSM, and the PDF is for 89-90 European S13 not for 240SX, despite what they labelled the file as. Hadn't used it for enough of anything to notice.
F3600
where did you see the Ka with a Dropping resistor?Humm never seen one in my car.. ill look in my fsm
biosehnsucht
Only SOHC KA's, not DOHC.
See above, I'm wrong
F3600
I owned 2 SOHc Ka and never seen a dropping resistor. injector on SOHC Ka are High impedance(?) about 13-14 Ohm.
the dropping resistor is for low impedance setup like the ca18det (2-3 ohm) ..?
anyway ill look in my fsm to be sure
Nismo1182
Car: Z06
KA-E and KA-DE NEVER HAD A DROP RESISTOR.
I know 100%. Ive done enough swaps to know.
The chip you are talking about is for the ignition coil.
biosehnsucht
Hrm, ... you're right.
The PDF for 89-90 240SX is then not a 240SX, I hadn't used it for much of anything so hadn't noticed, as I have an actual 89 FSM.
Now that I look at it, it's obviously a European FSM, since its got the CA motor in it.
I've edited my posts above to correct myself
