FS: CA18DET and a wealth of parts
fanta
My priorities have changed; a fun car will do me no good when I'm away at college. -CA18DETComplete from the throttle body to the exhaust manifold. $250
-CA18DET BlockMissing one oil squirter, lightly scored walls on cyl 4. No girdle. The remaining pistons/rods can be provided. $75
-RWD CA18DET oilpan $25
-OEM water-cooled oil filter housing $5
-CA18DET transmission, clutch and flywheel. $100
-A/C compressor
-CA MAF
-N60 MAF
-CA throttle body and TPS
-KA24DE throttle budy and TPS
-CA18DET CAS
-Coil pack set
-Ignitor and mounting bracket
-CA18DET injector resistor box
-Turbo oil and coolant lines
-pullies, alternator, starter
-SSAC T3/4 top-mount exhaust manifold $90
-A great deal of miscellaneous braces and other pieces.
I'm located in San Diego, CA. I would prefer not to ship the larger pieces, but we may be able to arrange something. Pictures can be provided. E-mail is key: [email protected]
Modified by fanta at 7:42 PM 9/23/2006
Modified by fanta at 1:22 PM 12/17/2006
Black on Gold
Where are you located?
fanta
Post edited.
Black on Gold
Ouch, Thats a bit far.
Good Luck
tyrannix
Car: go big or go home
email sent
CJ
tyrannix
add the crank to the list of parts i want too, and ill be in san diego the week of the 18th this month
CJ
kahlistrophic
Car: 92' 240sx base
email sent
eliterit
Car: pignose
how much for the water pump pulley overnighted to 78245?? and how much for just regular ground shipping
nightstepper
Car: my girlfriend, my project car, and partying
Do you still have the CA ecu? If so is it for the manual transmission? Im interested if you still have it.
fanta
nightstepper wrote:Do you still have the CA ecu? If so is it for the manual transmission? Im interested if you still have it.
The ECU is for a 5-speed and is still available. My e-mail failed to reach you; send one over.
eliterit
Car: pignose
paypal sent for water pump pulley.
please ship out asap via fedex home delivery.
thanks
nightstepper
My email is [email protected]
Hit me up with an email so we can discuss this ecu thing. Thanks.
nismolaos85
Car: 91 S13 Capowered
email sent
Dattebayo
Whats the deal with the A/C compressor?
[email protected]
nightstepper
Email sent about the ECU. Thanks
eliterit
Car: pignose
thanks for the pulley.
do you happen to have the power steering pump bracket? as well as that fitting adapter thingie that bolts onto the power steering pump which lets the high pressure line connect to the pump??
i need both of these items
kahlistrophic
Car: 92' 240sx base
emailed you again..
fanta
eliterit wrote:thanks for the pulley.
I'm glad to hear it arrived unscathed. The remaining pump bracket is for a HICAS pump; I'll have to check on the line adapter.
fanta
Post edited
eliterit
Car: pignose
so this pretty much means the hicas bracket is different?
Ca_laurier
i forget the name of the sensor, but ist one on on the intake manifold pointing towards the valve cover. very interested in that.
fanta
Ca_laurier wrote:i forget the name of the sensor, but ist one on on the intake manifold pointing towards the valve cover. very interested in that.
Brown plug or light blue plug?
91rs13
Car: Nismo 350Z
Datsun 510
Dodge Ram 1500
Oil pan still available?
If so--how much shipped to 12018
you can get me at d510 at nycap.rr.com
ThanksDJ
Ca_laurier
fanta wrote:Brown plug or light blue plug?
fanta
91rs13 wrote:Oil pan still available?
ThanksDJ
Yes, the pan is still available. I'll have a quote for you by tomorrow morning.
tyrannix
+1 good seller, he had all the stuff relativly clean and laid out on a table when i got there
btw, checked the acct, everythings good Miguel
CJ
Rage_sixtynine
Car: ca'ed '90 240sx coupe
Do you have a good and straight power steering pulley for sale? if so, how much shipped to 43017? Thanks,[email protected]
fanta
I
eliterit wrote:so this pretty much means the hicas bracket is different?
believe the mounting bracket is different, but you may want to check on that. My memory's a bit fuzzy.
fanta
Ca_laurier wrote:
I only have one left, and that will be going with the complete CA18DET until further notice.
fanta
tyrannix wrote:+1 good seller, he had all the stuff relativly clean and laid out on a table when i got there
CJ
I'll try to have more saran wrap next time
I deposited it this afternoon. Hope the trip went well.
