AEM 30-1620U for Nissan Z32 1990-1994 VG30DE(TT). Condition is Used. This system will mate right into the stock ECU socket, some custom wiring required for MAP and AIT sensors.
What you'll get:
-AEM 30-1620U ECU (on-board UEGO controller aka wide band sensor)
-Original AEM install CD with software and support documents.
-AEM 30-2130-50 3.5bar MAP sensor w/ pigtail.
-Original AEM box
-AEM ECU data cable RS232-USB
-AEM 30-1620U wide band sensor cable (connector on ECU side will need some repair; NOT PICTURED)
This is a 90% plug and play standalone ECU for Z32 TT or N/A; you'll need to switch to a Speed density/MAP system to use this ECU in place of the stock MAF system. Buyer has to secure a CAS trigger disc other than the stock trigger disk, donor vehicle had an AEM 30-8761 trigger disk (NOT INCLUDED) & a AIT sensor AEM 30-2010 (NOT INCLUDED).
THIS WILL NOT WORK UNLESS THE MAP, AIT SENSOR ARE WIRED AND THE CAM TRIGGER IS INSTALLED. Contact your local tuner/mechanic/technician if this system will suit your needs. Not sure if the ECU will support two wide band sensors at once; UEGO plug will need some repair, the red terminal wire comes out. After installation you will need to calibrate the computer for your particular vehicle and setup.
Contact AEM for help sourcing these parts if you are unable to find them from a retailer/local store.
Buyer or buyer's agent are responsible for complying with their local laws and regulations relating to this kind of electronics device.
***NO RESERVE***
$400; you pay for shipping or pick it up. PM or eBay listing for contact.
Happy bidding. https://www.ebay.com/itm/154041598472
