the good.
the car has new alternator, water pump, starter, rebuild 300zx 30mm calipers front and rear, new cross drill rotors front and rear, new stainless steel brake lines,front and rear, new 300zx brake master cylinder, the car has sentra electric fan upgrade, msd coil upgrade, msd 6al ignition box. the car is lower with eibach spring with kyb struts. the car also has a new rear window switch and trunk struts from nissan. i charge the a/c the beginning of the summer. also 3k miles on new tires on powdercoated s14 se wheels new 5 lug conversion with new control arm ball joints and hub front and rear. the car also has s14 seats fornt and rear.
just pass nys inspection
