elwesso wrote:Dont buy a Q. That is the BOTTOM LINE
You will need at least an extra 2 grand out fo the hole to get everything up to spec and then you can toy around from there on things that may not be needed.... Then throw in some extra for the active suspension.
Every used car has deferred maintenance, hence the discounted price.
If $4500 is your budget, look for a simple four cylinder car that costs no more than $2K so you can effect the necessary repairs.
Personally, I would drive the F50 because depreciation doesn't slow very much just because you are not driving it.
Modified by maxnix at 12:21 PM 12/26/2006
