FRSport Deal of the Day:SPLParts PRO Rear Traction Arms 350Z
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
FRSport
Deal of the Day: SPL Parts PRO Rear Traction Arms 350Z
Just add the item to your cart to get the discount price.
SPL's pro rear traction arms eliminates bushing flex in the stock arm to reduce toe change in the rear suspension
under hard acceleration/braking and when going over bumps. This provides more stability and predictability to the
rear suspension for optimum handling. SPL's traction arms are also length adjustable to allow the rear suspension
geometry to be adjusted for bumpsteer.
  • 1.25 4130 chromoly tubing construction for strength
  • QA1 3-piece 20mm chromoly rod end with teflon lining provides low friction for maximum performance
  • Adjustment specs: Length adjustment range is +/- 0.75 inch from stock arm.
  • 1 available at this price
Available for 1 day only for $229.95 <--click here for more info
*price good while supplies lastadd to cart to receive discounted price*
Thanks,
FRSport Team
AIM: FRSportsales
Email: [email protected]
[/size]
Return to “Advertisers' Marketplace!”
