Available and IN STOCK
FRSport.com is now exclusive importer of Siruda head gaskets in North America.
Established in 1988, SIRUDA high performance gasket is a renowned manufacturer of gasoline/diesel engine gaskets and overhaul kits for all major car brands.
Having several decades of professional manufacturing experience, SIRUDA is also well known as the outstanding designer and developer of dies/molds for gaskets.
SIRUDA high performance gaskets are manufactured through the adoption of the most advanced production techniques and equipment.
SIRUDA’s goal is to provide highest quality to meet the need of the latest generation turbo-charged high speed engines running under the toughest condition.
SIRUDA achieves it by controlling the entire manufacturing process - from designing, tooling, producing to the final products.
Through continued product research and development, modern management and professional sales and marketing policy, SIRUDA has now become gasket of the first choice among motorsport circle.
Siruda Metal Head Gasket Sizing Availability
SR20DET
Bore Size: 87mm | Thickness 1.1mm | Grommet Type
Bore Size: 87mm | Thickness 1.2mm | Grommet Type
Bore Size: 87mm | Thickness 1.5mm | Grommet Type
Bore Size: 88mm | Thickness 1.2mm | Grommet Type
Bore Size: 88mm | Thickness 1.5mm | Grommet Type
Bore Size: 88mm | Thickness 1.8mm | Grommet Type
RB25DET
Bore Size: 87mm | Thickness 1.3mm | Grommet Type
Bore Size: 87mm | Thickness 1.6mm | Grommet Type
RB26DETT
Bore Size: 88mm | Thickness 1.0mm | Grommet Type
Bore Size: 88mm | Thickness 1.3mm | Grommet Type
Bore Size: 88mm | Thickness 1.6mm | Grommet Type
Multiple Layer Steel Manifold Gaskets
This type of gasket has better strength against exhaust pressure and corrosion because it comprises of multi layers of steel. The outer layer is coated with HR-180. It has excellent sealing capability for high power engines.
HR RUBBER COATED MATERIAL
A Fluoroelastomer is a special purpose synthetic Rubber. It has wide chemical resistance and superior performance, especially in high temperature application in different media.
HR-180 rubber coated material that is heat-resistant to 250?C/ 482?F. HR-180 is designed to meet the demands of a variety of harsh sealing environments, load conditions, and surface finishes.
Exhast Manifold Gasket
SR20DET OEM Replacement Exhaust Manifold Gasket
SR20DET OEM Multilayer Exhaust Manifold Gasket
SR20DET Large Bore Multilayer Exhaust Manifold Gasket
Intake Manifold Gasket
S13 SR20DET Intake Manifold Gasket
S14 / S15 SR20DET OEM Intake Manifold Gasket
Intake Collector Gasket
S13 SR20DET Intake Collector Gasket
S14 / S15 SR20DET OEM Intake Collector Gasket
SR20DET Turbo Inlet/Outlet Gaskets
SR20DET Turbo Inlet
S13 SR20DET T25 Turbo Outlet [5 Hole]
S14/S15 SR20DET T28 Turbo Outlet [5 Hole]
PLEASE PM FOR NICOCLUB MEMBER DISCOUNTED PRICING
