FRS ARP Head Studs + Cometic Head Gasket SR20DET Combo
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
FRSport
Details:This Combo Deal consists of ARP Head Studs and Cometic Head Gasket (87mm x 0.040") for the SR20DET. This package will reinforce the head and block together and seal the head properly.
ARP Head Studs:
* Replace your stock head bolts with ARP heavy duty head studs. The stud design helps the head and the block equalize the pressure better thereby creating a much more even and consistent seal. It is recommended to replace the head studs/bolts with a new set if the head bolts are ever loosened due to metal fatique. Reusing an old and possibly warped or stretched head bolts/studs will sacrifice the seal between the head and block and may cause head gasket leak. This is a great an easy upgrade when doing an engine rebuild or building a race motor.
Cometic Head Gasket:
* Cometic MLS (Multi-Layer Steel) head gaskets are made of 3 layers of stainless steel. Cometic uses stainless steel for increased strength, ability to rebound, and resistance to corrosion. The outer layers are coated with Viton and beaded for perfect embossment. Viton is a fluoroelastomer rubber-based material that can withstand 482°F and able to seal the most harsh environments such as high load conditions and different surface finishings. The center layer is uncoated which can be varied to accommodate multiple thicknesses.
FRSport.com is offering a special combo deal for nico members for only $204.95!! Don't miss out on this great deal!!!
Thanks,FRSport.com Team
AIM: FRSportSalesEmail: [email protected]
Return to “Advertisers' Marketplace!”
