tytamto »
https://forums.nicoclub.com/tytamto-u122337.html
Fri Mar 27, 2009 4:36 pm
After a lot of research, I have decided to spend more money on the cryogenic rotors from Frozen Rotors. The difference ended up being a little over $80 vs. online cost of the OEM rotors, and I used a discount code.
I will be using new Hawk HPS pads that I already bought a while ago, and since I drive rather aggressively, the components usually get to temperature pretty quickly. No concerns here.
I will be around 38k miles at the time of installation. As far as I know, the front brakes are all original. The rotors have a little build up on them, causing annoying pulsation that did not go away with "bedding in" of the existing pads (per StopTech's instructions).
I will try to keep you all updated on the progress. I am curious myself if there really is a difference when it comes to these treated rotors. Only time will tell. And if there is not, I am only out $80... so no biggy. One less trip to the shooting range this month
Any opinions or experience with Frozen Rotors?
