so when you found the black button not working, you 'gave up'? you didnt think to use the physical key, nor the remote?ras_oscar wrote:it was about 25. No, I didn't try the remote. I needed to get in to find an ice scraper for another car. Ended up finding one somewhere else. To be clear, the rubber cover was flexible. it did not stiffen. Either the electrical connection or the switch was affected. Came back in the afternoon when the temps had cleared and all was well.
I suspect the OP didn't have it on their person at the time, which is why A) the locks didn't work, B) they didn't think to use the physical key, nor the remote.ImStricken wrote:so when you found the black button not working, you 'gave up'? you didn't think to use the physical key, nor the remote?ras_oscar wrote:it was about 25. No, I didn't try the remote. I needed to get in to find an ice scraper for another car. Ended up finding one somewhere else. To be clear, the rubber cover was flexible. it did not stiffen. Either the electrical connection or the switch was affected. Came back in the afternoon when the temps had cleared and all was well.
i really hope that isnt true. because that would be EPIC failure on multiple accounts lolRogue One wrote:I suspect the OP didn't have it on their person at the time, which is why A) the locks didn't work, B) they didn't think to use the physical key, nor the remote.
