Frontier Xterra Power Steering Idler Pulley Adjuster Bolt
Q451990
So I got a little heavy handed and broke the idler adjuster bolt for the power steering belt on my Frontier. Nissan apparently only sells the idler as an assembly, so I thought I'd save anyone else with this problem the step of figuring out the measurement of the bolt. It's a M8 x 1.25 x 80mm. It actually measures 78mm long, but 80 or even 90 would be fine.
In my case I couldn't find one at Lowes, Home Depot, NAPA, O'Reilly, Auto Zone, or Advance Auto. Napa had a place for one, but no bolt. Everyone else didn't even stock it. Instead of waiting for a few days for one to arrive, I was able to scavenge some from the Pull-a-Part. Nothing like a 10 minute belt replacement that turned in to a four hour project. It appears that both 4 cylinder and 6 cylinder versions of the 00-04 Frontier and Xterra all use this same bolt, if you're hunting a donor vehicle.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
good info. ACE Hardware generally has a pretty good selection of metric bolts too.
Ugh. I broke 2 idler adjusters / tensioners IN A ROW on my daughter's Camry. Good info amigo!
