Soon »
https://forums.nicoclub.com/soon-u260246.html
Fri Oct 21, 2016 8:57 am
Hi all
Just to let everyone know I did put the rails on the sides as well.
The problem was that with this version of the truck (SV) , the bed is not set up at all for the side rails.
On the Pro4x model there are brackets welded to the bed sides that the rails are then bolted to. I was going to just bolt to the bed in the same location, but even if I had a hoist it was going to be nasty. (very difficult to reach up into the fender) All of a sudden, I noticed that the downward lip of the top edge of the bed was the same width as the rails. It was easy to install the rails there. They are about 6" higher than the stock height but great for what I need them for.
Of course, this modification is not engineered, so I'll keep the loads moderate. That said, it would take quite a bit to rip the bed apart, and I now have tie down points wherever I want them. Cargo stays put.
I didn't stop there though. I built a half-length, rolling bed cart.
How's that for a teaser?
