frontier upgrade
max-8508
Car: FRONTIER
hi
i want to upgrade my frontier 2004 (ka24de) 2wd :naughty:
and buy somethings from ebay ,but first i want to be sure it is compatible with my car :poke:
1-Throttle Body
http://www.ebay.com/itm/Universal-Alumi ... 6rk%3D1%26
2- Fuel Pump
http://www.ebay.com/itm/1998-2004-NISSA ... e0&vxp=mtr
3-fans
http://www.ebay.com/itm/ALUMINUM-RACING ... v4exp=true
4-plugs
http://www.ebay.com/itm/91-98-240SX-KA2 ... 4d&vxp=mtr
5-Alternator
http://www.ebay.com/itm/Nissan-240SX-19 ... ca&vxp=mtr
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Plugs and wires, ok, it's Maintenance items. The rest... why would it be needed?
max-8508
Car: FRONTIER
i want more horse power
Throttle Body:enter more air
Fuel Pump:pump more gas
fans:it is hot in my city
Alternator:better than old alternator(old 70-new 90)
can you tell me is it compatible with my car???
GTR PrYdE
Throttle Body:enter more air That will not net you more power alone on a stock KA and probably won't fit without modifications and wiring changes for TPS
Fuel Pump:pump more gas That will not help you alone. You would need A turbo, supercharger, nitrous to need more fuel than your current fuel pump can provide
fans:it is hot in my city Is your truck overheating? If not it might be a waste. Fans require wiring changes for the temperature adjustment and a thermoastat change might also be needed. These fans don't look plug and play.
Alternator:better than old alternator(old 70-new 90) Only needed if you're suffering from low power now, such as having a stereo system with subwoofers or HID's or electric fans. can you tell me is it compatible with my car???
GTR PrYdE
If you were looking to add nitrous/turbo/supercharge/ your truck, these "upgrades" would serve a better purpose. On a stock truck, none of these are needed, nor will net you noticable gains.
max-8508
Car: FRONTIER
ok, if i put in my car supercharge , what i need to install it??
is this enough and good for my frontier ??
http://www.ebay.com/itm/KA24DER-com-240 ... 7e&vxp=mtr
GTR PrYdE
No, that's not all you need. This is where you'll need to read around this forum alot and search alot to find out how these things work. That way when you start installing these parts and run into an issue, you can have a better understanding of how to fix it yourself instead of asking around on the forum waitin for an answer. Not trying to be a jerk, it will help you in the long run.
max-8508
Car: FRONTIER
then,how much money do this want??
do i buy this supercharge now??
i want to use my frontier daily , is this good??
GTR PrYdE
Don't buy anything you plan on doing yourself unless you:
-Know how it works
-Know how to install it
-Have a means to install it
If you plan on having a shop work on your truck, then you can get advice from them since they'll be doing the work, but try to find a place on here that you know works on import vehicles.
Cost?? To supercharge, probably 2000-3000 after it's all said and done
max-8508
Car: FRONTIER
i want to use my frontier daily, is that good??(after supercharge)
GTR PrYdE
Yes that's fine if you use quality parts and tuning
max-8508
Car: FRONTIER
thank you very much :dblthumb:
