frontier trouble code P0455
bestblinds
Car: 89 pathfinder/ 2002 frontier
This code shows up intermittently. I don't think it is the fuel cap. Any suggestions on troubleshooting this problem. 4 cyl/ 2wd
s13sr20chris
p0455isnt that an evap leak code? i cant remember. if you are sure its not the gas cap then you are in for a tough diag(usually). if its a leak code then you need to check all the evap hoses and lines for cracks and stuff. the most common culprits are the carbon canister due to wrecks.
