FRONTIER PRO EX-VAPOR CANISTER ?
Skimelance
Car: 2019 Nissan Frontier Pro 4x
Greetings- first post
Not very car savvy, so hoping for some advice.
70K service performed, 2 days later check engine light on
Back to dealer, advised VAPOR CANISTER for engine emissions needs replacement. dirt in the canister.
OK, I advise, but then presented with a $958.04 invoice for replacement parts, and 2 days after this inspection, check engine light now off.
In reviewing replacement parts on Nissan parts.com
Vapor Canister$306.55
ok
but
Part number 17221-9BG0B- Filler tube, which appears to be the tube that feeds gas from the pump to the gas storage tank
Do I really need this @ $334.46?
Not sure if necessary or dealer just adding parts to run up price?
Any advice greatly appreciated
Thank you
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's a bulletin for all the Frontiers '05~'19 for P0448, it calls for replacing both the canister and fill tube. If that's the code you had, they would have performed the bulletin verbatim:
https://static.nhtsa.gov/odi/tsbs/2022/ ... 0-0001.pdf
