offroader »
https://forums.nicoclub.com/offroader-u128494.html
Fri Mar 06, 2009 8:57 pm
My 2000 Frontier crewcab 4WD 3.3L V6 with 165,000 miles overheated a few months ago. Added coolant and it was fine until 2 weeks ago when it overheated again. Coolant had splashed around front of engine but no obvious leak except seepage at top radiator rim.
Took it into a shop, they said block test OK, did dye test and replaced radiator, thermostat and fan belts. Cost $700. Picked it up and the check engine light was on. They said it was on when they started it up. Overheated again on way home. Didn't blow steam but would go up into hot range for a little while then go back down and repeat. Was now blowing white smoke and dripping water out the tailpipe. Turning on heater to try to bring temp down but it only blew cold while hot but warm when the engine temp was normal.
Took it back, they said block test now shows hydrocarbons in coolant; recommend rebuilt engine at $6000!
Did web search and ordered Steel Seal. Supposed to be a permanent ,non particle, thermochemical sealant fix. Put it in radiator, idled engine 30 minutes, let it cool and repeated. Drove it home, smoke stopped, no water dripping, didn't overheat, check engine light went out the next day.
Was fine for five days, then overheatingstarted again and check engine light came back on. Didn't see any white smoke or water dripping. Called Steel seal, they said do compression check and take out low cylinder plug and repeat treatment. Sent me some more.
Took it to another shop for compression check today. They said it idled for an hour without overheating, no hydrocarbons on block test but the water pump was leaking. They checked 4 cylinders , said they were fine at 150 and are going to finish checking the other two that are hard to get to in the morning.
I'm wondering why the water pump leak didn't show up before. Maybe overheating blew the seals? And maybe the radiator rim before?
Even if they say the other 2 cylinders are OK, I'm kind of reluctant to spend another $800+ for the pump and timing belt and maybe still have a blown engine.
In the last few months I've spent $1100 for a knock sensor and $700 for a rebuilt distributor and shaft.
Any suggestions or advice?
