Frontier and 240 Cams??
TrueSlide
Car: Stuff
My friend has a 96 frontier with the SOHC in it. I was wondering if the 240 cam would swap right in? If so would it give a noticeable amount of power? Would the swap be good, since he only wants alittle more power then stock? Any other info is appreaciated!!!
Also whats the different lifts/duration of the 2 cams?
TrueSlide
Car: Stuff
Err sorry I meant the XE!
Nismo_Freak
Car: 89 Nissan 240SX
The 240 cam is a higher end cam and will give you a gain of around 5 hp top end. It will move the powerband higher up as well.
technoman
Car: puss
I suggest you use the Nismo cams they will make more torque!Im not 100% on you fuel and intake setup Your ECU might not like them.
