Frontier 2000 king cab...brake light is on...
jtfsr
Car: Nissan Frontier
9 I have brakes but theres a clicking noise when I press the brakes..its coming from under the glovebox. Any ideas?
Modified by jtfsr at 10:36 AM 3/5/2007
Ramius83
Car: 1995 240sx SE
Check your brake fluid reservoir. If it is low, then you need either front and/or rear brakes.
That clicking you here is the interlock switch located in your center console, around your shifter area. Everytime you press the brakes, the interlock switch activates, letting you shift out of Park. It is normal for you to hear this click.
If you checked out your brake reservoir and it is full, then you have a broken component or short somewhere, ie broken brake light switch on brake pedal, broken grounding wire on e-brake (foot brake), etc,
