frontend conversion
Kuruption
I have a 95 240sx, i recently had damge to my front, so i was thinkin of going with the 97-98 front stlye, if i get the fenders hood, lights and bumber will everything fit properly? or do i end additonal brackets and shyt? how easy will it be? thanx in advance.
S13Sil-line
Car: Full throttle-*** out sideways
Most likely will involve brackets. you can get those where ever you get your front-end
EazyBreazy
from what ive read searching the only brackets that have to be changed are the bumper mounting brackets....the price of that conversion is almost equivilent to an s15 conversion. i had to deal with the same scenario but ive kept mine with the zenki front. it grows on you plus you can find parts in junkyard alot easier than the kouki. use http://www.car-parts.com to source used parts from junkyards all over the states. probably gonna be cheaper than dealer parts
