didnt read they were z33 brakes. i failnightsauce wrote:i say you get the brakes then invest in some rotors. I just did the swap and didnt need any mounting plates or nothing. I just bolted mine on and it worked just fine.
we make a conversion to use the brembo 12.7 inch rotor with z32tt calipersOutToWinPAHC wrote:I run Z33 track rotors with 17's. They clear, but I use the Z32 calipers. Im sure someone make a conversion for the brembos
my thoughts exactly. thats way too good of a deal to even think aboutmrgreeneyes wrote:for $100, buy them.
then figure out the bracket situation.
they are specifically made to fit the z32 caliper with the 12.7 inch rotor.240lookis wrote:corean surfer - do you happen to know if that adapter works with z33 calipers? it sounds like it will be able to accommodate the larger rotors, but will it work with the z33 calipers?
