Front windshield wiper problem.
nismo300zx1990
Car: 1990 300zx NA
I am having trouble finding whats is wrong with my front windshield wipers. I check the fuze in the car under the driver side dash and it looks fine. Is there a wiper relay that i should be checking or do the wiper motors go out on these often? any insite would be very much appriciated.
Also my back wiper and sprayer works great. but i can not hear anything from my front ones at all. the spray pump dont work either. Is there a fuse that im missing some where?
nismo300zx1990
Car: 1990 300zx NA
I dont know if my wiper motor is bad or i have a relay out. I have looked every where. I find it very weird that my back one work just fine but my front one nothing works. not even my spray motor will work. Has anyone out there had this problem?
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
wipers-not-working-t509032.html
Leave the wiper switch on and wiggle the fuse around, could just be loose.
nismo300zx1990
Car: 1990 300zx NA
Thank you for the reply. I just tryed wiggling the fuse and still nothing. Maybe its the switch? I dont really know. Or the motor.how can i check the wiper motor?
nismo300zx1990
Car: 1990 300zx NA
Also would anyone know where the ground is for the motor?
t.mcginley.jr
1966 Ford Mustang
You can apply 12 volts directly to the motor. If the windshield wipers move then its not the motor it's the switch/relay.
nismo300zx1990
Car: 1990 300zx NA
Ok is there a special way to pull the wiper arms off. I cannot seem to get the off and i dont want to pry them on in fear of breaking the black plastic.
t.mcginley.jr
1966 Ford Mustang
You should be able to remove the plastic cowl pieces (about 4 clips/plastic screws) and then take the wiper assemblies apart
nismo300zx1990
Car: 1990 300zx NA
Ok did all that and started to check for power and im not getting power to the wiper fuse. What would u cause that it all the sudden did this? I believe that is why they are not working but dont know what to do to fix that.
t.mcginley.jr
1966 Ford Mustang
Check out the wiring diagrams in the "Everything you need to know about Z32's" post. I'm not sure how the wiper system works exactly but I do know the power should go to the fuse first and then to the motor. So if you aren't getting power to the fuse then something before that is messed up. Not sure if the switch/relay is before the fuse. Maybe a loose connector somewhere? You could just get a new fuse anyway and check that first.
