front wheels and offset +brakes
ssmrico
Car: 2011 Infiniti M37 S
whats the lowest off set from 43 that can be ran in the front 20x9 or 20x9.5 that clears brakes with no spacers?
wideopn11
Car: 2012 Infiniti M37x Moonlight White
Takeda CAI
Stillen exhaust w/ MeganRacing Y-pipe
SCALE coilovers 16K/10K F/R
Akebono BBK
Cusco strutbar
25mm spacers F/R
Uprev tune by seymore4
Not sure I get what you are asking. At OEM +43 there is little to no gap from the wheel spokes to the calipers; it's a super tight fit. In the other direction you can go to +23-+18 and be flush with the fenders (depending on suspension and tires). This puts more space between the wheel spokes and the calipers.
ssmrico
wheels that came with car have spacers without them they wont fit and I hate it, trying to find same wheels but with the right offset where I don't require any spacers
30 or 15 offset what I found for 20x9 so far fml
wideopn11
Takeda CAI
Akebono BBK
Cusco strutbar
25mm spacers F/R
Pic?
k67p67
Car: 2015 Infiniti Q70 Premium
2017 Nissan 370Z Nismo Tech
Changing offsets doesn't change brake clearance. Spoke articulation and disc/pad size determine whether a wheel will clear your brake calipers.
Malbec 56 Beast
Car: 2013 Infiniti M66xS Totaled 4/11/20
What's next???
2010 Subaru Legacy
1983 Porsche 928 S Euro (Sold) 2/17/20
So I added 25mm spacers too my 20x9 et43 wheels, that give it an offset of 18. That doesn't mean you can order a 20x9 et18 will fit. I to was hoping that there was a chart to assist. The spoke size, direction, concave, convex all play a part in fitment. Most wheel retailers will tell me the only way to verify is to test fit. But if it's a different wheel your test fitting to one that is on the web it's still crap shoot.
Let me know if you find the magic potion.
Good luck
Andy
ssmrico
true. ill just put stocks on. sell these and get a new set eventually
