Front Wheel Noise
Amosnorider
Ok so Im still combing thru my new to me I30. Looking for any necessary repairs.I have noticed a very quite hum from the front left. Its really only noticeable between 15 and 30 mph. Also makes the noise when coasting out of gear. Cannot feel anything in the brake pedal that would suggest warped rotors.Wheel Bearing?Brakes????
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
I'd lean towards the bearing, with the exception of the fact that it only does it from 15-30 MPH.
Amosnorider
Yeah i know its a little perplexing. I think that road noise muffles the noise coming from the wheel at higher speeds. It does not squeak though. Kinda sounds like i have one knobby snow tire installed. I didnt think wheel bearings went bad that often. Not too sure thoughOther suggestions?
time_tracker
What about when you drive make quick move with steering wheel one way and then the other and see if it will go away. If it will, it`s bad bearing.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Might be a busted belt in the tire?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
It's probably the wheel bearing. Have it checked and replace ASAP once confirmed bad. If not, the hub can also be damaged.
Rod
