Front Wheel Drive Question
All things Altima Coupe.
gordo
Car: 2008 Nissan Altima Coupe 2.5 S
Does the FWD drive both wheels or just one? I can't seem to find an answer.Just bought my coupe yesterday evening.
++ Gordo++
packerjd04
Car: 2008 Nissan Altima S 2.5 Coupe
FWD is power to both front wheels.
Dr4gonCoupe
Car: 2008 Altima Coupe 2.5S CVT
um FWD means traction in the front two wheels.
Scandinavian Flick
Car: 2008 Nissan Altima Coupe 3.5SE
to the best of knowledge, both wheels are driven, if only one was driven the car would pull to the left or right non-stop, now there are clutches inside the transmission that will allow one wheel to spin faster then the other that way you are capable of makin turns, because when you go around the corner the outside wheels have to spin faster then the inside wheels, the reason cars torque steer is because the driveshafts are not of equal lengths, so when you stomp on the gas the shorter driveshaft doesnt twist as much as the longer one and gets the power to the wheel slighty faster then the longer driveshaft, but if you are wondering if you pull the e-brake and dump the clutch and sit there to burn your tires are both tires goin to spin? odds are No. Only one tire is going to spin, the transmissions differential will only send power to one wheel. but for your drag strip launches, you will get power to both wheels. so hopefully i answered your question, maybe even some questions you didnt ask.
Scandinavian Flick
just some real quick info, all FWD cars drive both front wheels, but not all RWD cars drive both tires
leif927
Car: Nissan Altima Coupe 2.5S
I think he's asking about LSD(Limited Slip Differential)...of which i don't think our coupes have, only the 3.5s come with VDC (Vehicle Dynamic Control)[Optional on 3.5] and TCS (Traction Control System)[Standard on 3.5].
D-Roll
Car: 08 Nissan 350Z Touring Coupe
leif927 wrote:I think he's asking about LSD(Limited Slip Differential)...of which i don't think our coupes have, only the 3.5s come with VDC (Vehicle Dynamic Control)[Optional on 3.5] and TCS (Traction Control System)[Standard on 3.5].
I agree! And no LSD in the coupes unfortunately
gordo
That was point I was getting at. Thanks.
code08red
If its fwd does that mean its suppose to pull to the right/left?
I'm having this problem and I dont want to take it to the dealer for no reason.
I'm not tryin to take over your thread!
Scandinavian Flick
it shoudl only pull to the left or right if you smash the throttle and only for a moment, and actually the a/c has very little torque steer for a FWD, so if your car is pulling constantly, its alignment is out.
code08red
It pulls ALL the time...I recently took a mini road trip and I noticed that the ride isnt as comfortable as my old car (tc). I kinda regret gettin rid of itI do have 20's I'm not sure if that makes a difference?
maxentropy
Car: '08 Altima Coupe 3.5SE
Check your wheel alignment.
Scandinavian Flick
your alignment is out, as for the ride quality thats the joy of 20's, those rims require you to have much less sidewall on your tires, therefore the tires arent absorbing the road as much, is your car lowered?, also dont regret letting the tc go, the a/c is way better, and thats not just because i own one, ive driven the tc.. its not bad... just the a/c is better
code08red
No its not lowered I would like to get it lowered eventually, a/c turns many more heads then the tc
I went ahead and contacted the dealer ...Thanks for all the info
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
20s may be the issue, got a 35 profile on em?
code08red
LongBeachCoupe wrote:20s may be the issue, got a 35 profile on em?
Yes, they're 35
PhillipRumans
Car: 2008 Nissan Altima Coupe 3.5 SE
Regarding putting bigger wheels and tires on the car, does it lighten the steering up with the bigger tires? Does the steering start getting a little squirrely with 19's and 20's?
dkgordon
Car: Nissan Titan
Phillip,
I have 19's and didn't notice a difference aside it handled better. That's probably more due to the better tires though.
spockrock
Car: Altima Coupe 3.5se
PhillipRumans wrote:Regarding putting bigger wheels and tires on the car, does it lighten the steering up with the bigger tires? Does the steering start getting a little squirrely with 19's and 20's?
if the wheels weight less then yes from what I have read handling does improve, but how much I am not sure.
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
code08red wrote:It pulls ALL the time...I recently took a mini road trip and I noticed that the ride isnt as comfortable as my old car (tc). I kinda regret gettin rid of itI do have 20's I'm not sure if that makes a difference?
that makes a HUGE diffrence bigger wheels mean more noise n less comfort thats wat i have n i only got 18's
code08red
Thanks for all the help
heeroguy
Car: altima coupe 3.5
fwd can have open and lsd front diffs, open will allow the tire with least tration to get power
lsd will give power to tire with least traction after a certain threshold it will give equal power to both
