loystock »
https://forums.nicoclub.com/loystock-u10145.html
Mon Aug 10, 2009 8:45 am
Limited slip differential is standard in the touring model, optional on the base. Here is an info for a 99 I30 which may apply to your car.
On the base I30 model, the limited-slip differential (LSD) was an option. On I30 Touring models, the LSD was standard. Please confirm the correct type of differential on the vehicle before ordering seals for I30 base models. Check the model ID # (NOT the chassis #) at the ID plate on the firewall. The final 5 digits after A32EUA or A32EVA are the option codes. If the first digit is code C, P, or Q, then the vehicle is equipped with a LSD.
