disallow »
https://forums.nicoclub.com/disallow-u261384.html
Tue Sep 13, 2016 5:46 am
I recommend you do the hub assemblies, unless you have a tonne of experience pressing bearings into really inconvenient spaces... you'd need a press and probably some spacers etc to make sure you could press it in. Also haven't found the listing for bearings only, so you'd have to hunt that info down too.
The test for the wheel bearings is to take the wheel at 10 and 2 o'clock and try to move it. If it has any axial play, the bearing is done and needs to be replaced. Its usually pretty pronounced, and you should do it with the tire on as it makes it easier to move. Make sure that your outer tie rod end it tight at the same time. You can check for play by grabbing it and moving in and out to see if there is play.
As far as the type of hub assembly, I've had good luck with Timkin, National, and Mevotech. But had bad luck recently on my 05 pathfinder with Moog. The driveshaft wouldn't push through the splines. Changed to a Mevotech and the problem disappeared, but not before 2 days of cursing and swearing and wondering what I did wrong, along with a flat bed ride to the shop and $1000 of charges (had him do my brakes too, we were under the gun for time).
So to summarize, check for play, if there is play, change with the recommended brands above. Do the assembly, not the bearing, unless you have a lot of experience with presses.
