JPK Omaha »
https://forums.nicoclub.com/jpk-omaha-u194653.html
Tue Jun 10, 2014 2:47 pm
Thanks for your feedback, I jacked up both sides last night and there was a very small wobble (about 1/16 or 1/8" play) in the right front wheel, the left side was tight). I took it in this morning and asked if they were replacing cup/cone? They said there were no parts to replace except a $17 seal kit which was included in the price. So I told them to do the right side only. Will keep my eye on the left side and if it gets loose will fix it later. The $ 272 was basically for 2.3 hours labor to do the bearing repack.
I also had asked them to check the rear suspension parts for wear. They said the rear sway bar bushings are starting to crack a little but are not loose, they have a small amount of play, but did not recommend replacement at this time. I still have the original shocks at 132k. The vehicle still handles ok, no rust anywhere, so I will just keep driving it.
