timmack wrote:i was also reluctant to do it but once i started, it really was quite simple. i found this link in an old post and followed it to a T, it was dead accurate for my pathfinder. i got to thinking though when i was reassembling it that if you dont put the hub flange back on that you might get better mpg out of it because the front wheels will just spin feeely, kind of like a poor mans auto hub. of course youd lose your 4wd though until you pulled the wheel off and put the flange back on.
http://rkrenn.com/xterra/howto/bearing/bearing.htm
Great find Timmack! I used the guide to replace my cousins bearings on her 2001 Nissan Pathfinder, 4WD. The dealer told her it would cost about $500.00 - 600.00.
So I bought all the required parts:
inner and outer bearings and racessealsgrease
and using my own tools (no special tools) I followed the guide to the teeth as you did and accomplished the task over 2 days with one problem. When removing one of the seals I broke the rotor sensor (abs ring) in half.this caused the ABS light to come on because it didn't sense the ABS ring (rotor sensor) Braking power is not effected, and I will be removing the rotor again to replace the the ring. But replacing the bearings did give the truck a much more stable feel. So all should be careful when removing the seals. I also removed the snapring using 2 screwdrivers without a problem.
Thank you much for sharing that link, it saved her quite a few dollars.
Modified by hittz at 3:49 PM 7/25/2009
Modified by hittz at 12:07 AM 7/26/2009
Modified by hittz at 12:08 AM 7/26/2009
