oldmako wrote:Thanks Andy for the info.
I looked at doing it earlier, but decided to wait. The truth is I am not certain that they're bad. I have a vibration which I feel through my butt and slightly through the wheel. The problem is that it's intermittent and I can't decide what the hell it is. I have nothing to indicate that they were ever replaced and the car now has 155K, so they may be toast. Or as Jack mentioned, fine.
I have my tires rotated and balanced every 5000 and that helps, which leads me to believe it's a tire issue...but, at certain times, and at certain speeds the front end is wonderfully smooth. At 90 it's a gem. Problem is that I can't run the thing at that speed for very long, and the problem comes and goes. I would think that a bearing issue would be prevalent no matter the tire condition, and would manifest itself above a certain speed.
With old cone bearings you knew when it was shot due to high freq vibration in the steering wheel with perfectly balanced tires.
I have also heard others suggest that it could be my transmission mount, but I am unable to search on this site and find any info. No matter what I input to search, I get nothing. Not sure what's up with that. Perhaps I need to try a different PC.
I was going to do them last summer when I did my brakes but decided to pass because the issue wasn't that big a deal.
My current tires have 50K on them and still show an amazing amount of tread left, but by next summer I suspect they will be toast. Perhaps with new (and better quality) rubber it will be easier to diagnose.
From my experience, bearing failure is easy to diagnose (over time) because the bearings deteriorate EXTREMELY rapidly compared to any other component. If you've had this problem for 10k miles, and it hasn't worsened, it's definitely not a bearing. Even 5k I'd say...any bearings I've replaced have failed within 1-2k miles of first "making noise."
When you rotate tires, does the vibration sensation follow tires?Have you ever tested to swap rotors and see if it is a warped rotor, or perhaps a runout our of spec?
Stuck caliper could be suspect but unlikely...
My guess is 100% tires - even tires at 20k can develop these issues, even with proper rotation and maintenance. Sometimes bad things happen to good tires mako!
