Front turn signal bulb
Run262
Car: 91 Q45, 95 Q45, 95 J30
I have a 91 Q45. The right front turn signal bulb needs to be replaced. I've looked at the manual but could not find the instruction.
Do I need to take the light assembly out? If so, how?
Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yeah you have to take the assy out... Take the plastic cladding above the headlight off, and theres a thing that holds it on, unscrew it from the headlight..... Then gently but firmly tug on it, and it will come out... then twist and pull to replace bulb.
3rd Q
It helps if you have a mini pry bar or hose puller to get behind and gently pull the assembly out. It is held in by a ball and socket type bracket and will pop out if you work at it.Paul
Run262
Thanks for the replies.
So after I unscrew the top plastic cladding above the head light, just pull it out (horizontally?) toward myself, not up?
Thanks
96Qowner
Car: 1996 Q45
Towards yourself, yes. The tough lil ball thingy is at the bottom - pry there. It'll be obvious once you have the top screw off.
Q_SHIP
Car: 1999 Q45T with a billion miles.
How many NICO member does it take to change a light bulb?
HAHAHA... Just playin!
