front torsion bar anchor mount won't go back on
soundsailer
Car: 93 hardbody 4x4
took off the tension bars to do a clutch job on my 93 4x4 hardbody and one of the front torsion bar anchor mounts came off with the tension bar. Now it won't re align with the front spine mounted on the front of the frame ? What's the procedure to re align them? Thanks
This may help - I'll check in this evening and see if there's more info for you: https://nicoclub.com/archives/nissan-ha ... hings.html
Also, you should grab your FSM at nissanservicemanual.com for future reference.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You're going to have to loosen up the rear anchor first and then readjust ride height when you tighten it back up. Fortunately you have the other side of the truck to get your height measurement from.
