Front toe problems and alignment
nd_aussie
Car: 1994 300zx 2+2 bout to be tt&1987 rx7 s5 turbo II
Ok so I lowered my z and in happy with the way it turned out I'm now only having a prob with toe, I think only in the front though. Do I adjust it by the rack and pinion or what?
es.biggs
Car: 1990 300ZX 5sp NA
You go and get an alignment. Not really something you want to do in your garage
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
es.biggs wrote:You go and get an alignment. Not really something you want to do in your garage
+1
You need a precision alignment rack to do this. A tire shop can do it.
nd_aussie
yea i know i really want to go and get an anlignment but they charge 80$ down here which sucks, i really wanted to at least fix the toe a little bit before i drive it.
Ace2cool
$80? I wish! The only shop that I can actually fit my car on their rack wanted $140. Please......
es.biggs
$80 is fair, pretty standard price for an alignment. You could see if they might discount you just to set the front toe (shop I used to be at we always called it a toe-n-go lol), but I wouldn't count on that.
Do you have another car to drive til then?
Ace2cool
es.biggs wrote:$80 is fair, pretty standard price for an alignment. You could see if they might discount you just to set the front toe (shop I used to be at we always called it a toe-n-go lol), but I wouldn't count on that.
If he just lowered all around, it's not tracking straight that he's worried about. It's tire wear.
Aussie, what's more expensive, a new set of tires or an $80 alignment? Weigh your options here.
car nut
Car: GT500.
Ace2cool wrote: Aussie, what's more expensive, a new set of tires or an $80 alignment? Weigh your options here.
:yesnod
Think about it like this: if your toe is off by .125"(positive or negative, assuming you're going for 0), it's pretty far off. Do you really have the precision tools and required skills to not only figure out how far out of whack your toe is but to adjust your tension rods and steering rack in the correct way to make it perfect? I honestly don't think anyone on this forum has that capability unless they work at a shop.
Go get your s*** fixed.
ArticDragon192
Car: 91 Z32 2+2
I guarantee you, your toe front and rear are screwed up. It is not something you can just eyeball. You need proper equipment and skill to be able to align your car. Take it to a shop and get it done properly. At the risk of sounding like an a**, stop being cheap and get your car set up right.
And no, a proper alignment shop will not just align your front. They align your front in relation to your rears. So if your rears are off, your fronts will be off as well. They will always straighten the rears first, and then move up to the front. Seriously, $80 is nothing when compared to a new set of tires.
nd_aussie
Ok I'm getting it aligned tommorrow
LIBRILZ
Car: 1990 Nissan 300zx
2007 M45 Sport
See, the problem I hear of people having is that their cars are too low to get onto alot of alignment racks. What do you do in that situation, im sure you've came across this.
ArticDragon192
Car: 91 Z32 2+2
Go to a guy whose rack my car can clear. So far, I have 3 places I can go to. My first choice has his rack modified to fit extremely lowered cars. Mine goes on with no issues.
nd_aussie
yea i got my car aligned today for 40$ from an amazing shop. brought almost everything into spec
nd_aussie
ok so heres my specs at the moment front left camber -3.5 front right -2.7, front left toe 0.03 front right toe 0.04, rear left camber -2.3 rear right camber -1.5, rear left toe 0.13 rear right toe 0.11
Ace2cool
LIBRILZ wrote:See, the problem I hear of people having is that their cars are too low to get onto alot of alignment racks. What do you do in that situation, im sure you've came across this.
Some places have completely flat alignment rack/lifts. No ramps to drive up, no edges to clear. People have been running slammed for years, and shops have found ways to get heir alignments done.
minlow88
Car: 93' 300z big piece of N/A
08' altima coupe
88' 4x4 s10
82' 280zx
39.99 for a 2 wheel alignment here in joplin mo.
They were free when I was in school.
nd_aussie
I got a 4 wheel
ArticDragon192
Car: 91 Z32 2+2
minlow88 wrote:39.99 for a 2 wheel alignment here in joplin mo.
Why would you do just a 2 wheel alignment? The rear isn't a solid rear axle. Lol.
Ace2cool
'Cause that's all the general population understands is that they need a front alignment, and people don't want to pay more money than they have to, so shops don't press it.
ArticDragon192
Car: 91 Z32 2+2
Sounds like misunderstanding.
nd_aussie
sounds stupid
car nut
Car: GT500.
Sounds like a great way to drive crooked!
SLE-PR
Car: 1992 Z32 A/T TT
1990 Z32 S/T NA
1990 Z32 A/T NA
Well said, I couldnt of put it more simple myself.
Aussie, what's more expensive, a new set of tires or an $80 alignment? Weigh your options here.[/quote]
