You hit the gas, the
seat slides back. You hit the brakes, the
seat slides forward. Just enough to annoy you every day, or potentially cause a safety hazard. Let's come up with a solution!
This thread will be a collection of investigations & solutions on how to remedy/resolve the seat slide issue once & for all. Note: This is a different issue from the seat rocking issue, where the seat pivots back like a rocking chair, or pivots toward the center console.
My initial investigation under the seat unfortunately opened up more questions. I thought I had the solution in hand after reading a post by another member about a replacement gear at
http://www.odometergears.com/products/I ... Present/98 Sadly, there is no mechanism with a cover that can be unscrewed - at least on the 2006 M35. The motor drives what looks to be a metal gear, which turns a long grooved rod. I can't see any way to get to the gear without removing the entire seat, and even then it is encased in a metal frame. Also, I rocked the seat forward & back while watching this gearbox, and I'm not convinced this is the source of the play. It looks taught. The play looks to be in the rails themselves (if that makes sense).
Here is a video to aid in understanding the gear, and how it is different than the replacement piece from the link above. This video is shot from the driver's footwell, where your feet would normally be. Nothing has been removed from the seat, it is simply all the way up.
[youtube]
http://www.youtube.com/watch?v=9PsbTI1kVAg[/youtube]
Hopefully this thread will inspire others to come up with solutions.
