gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Tue May 22, 2007 5:57 pm
If you have ever seen a cam-bolt, you will notice it has a lobe similar to a camshaft, also, it will be a bit thinner. If it is a quality piece, it will be made from tool steel and is very strong.You replace the uppermost stock bolt with the eccentric. The lower bolt is loosened just enough to to shift the strut on the spindle. As you turn the eccentric bolt, you will see the spindle moving in and out. This is how the camber is adjusted. Its not rocket science.Think of a camshaft acting on a rocker arm. Same concept.When the appropriate adjustment is obtained, you hold the bolthead with a wrench, and proceed to tighten the nut, so as not to loose your desired setting.
