180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Aug 21, 2004 5:08 am
the 24E? You don't need to drop the oil pan or pull the head. If you've pulled the bolts off the front cover, pulled the pulley on the left side of the motor, crank pulley, oil pump, distributor, and water pump, and got the bolts off, with a pry bar you can pop the front cover off. The points where I used for leverage was at the upper right hand corner to get the initial split in the block and front cover. From there it's pretty easy to pull it off but no you don't need to get all that out of the way. If you pull the radiator shroud it'll make for alot more clearance when you're doing this job. Also JNM240 is right about the cover going on before the head, if you've pulled both off, the cover should have gone on first then the head.
