Front Tension rod and caster
artemoushue1
Car: 1995 240SX se
1981 720 King cab 2wd
2009 Audi A4
Hi all,
I see tons of ball type front tension rods, I like the adjustability factor but I'd like to go a bit softer. I've also heard on several occasions that the solid bars can crack the crossmember. (any input on this)
I've lowered my 95 an inch (AGX's with Swift springs) and would like to dial the caster back up.
Has anybody had any experience with Whiteline KCA331 bushings or the Eibach Pro-alignment (SPC) adjustable tension rods? I currently have an Energy suspension poly bushing in it, but again, no adjustment.
Per my previous posts suggestions, I'm replacing the lower ball joint and the bushing (polyurethane) to stop the damned shake, hopefully this will help my on-center steering wheel feel.
Thankyou.
