Front sway bars in S13 with 2JZ swap
phuz
Car: 1993 2JZGTE S13 PT6266 HKS272
2006 Volvo S60R
I am trying to find out, definitively, which front sway bars are compatible with a S13 2JZ swap. I have not been able to find an answer. I thought that some of them worked as long as you used the spacers, so I got a set of Godspeed bars and installed the rear no problem. I attempted to install the front with the spacers and see that the front-most part of the bar contacts the oil sump, so it's a no go.
I see Sikky is for sure. Can't tell about Whiteline. What about others?
I am not interested in opinions of "this sway bar sucks". I am only interested in the list of bars that will fit with this swap. If you can't respect that, please don't post.
